Buschur Racing's GTR busts 1000 whp on stock turbofolds
- - - - - buschur racing sir cobb flex fuel bfic
13 replies to this topic
Buschur Racing
Buschur Racing
  • 2,360 posts
  • LocationWakeman, Ohio
I am FINALLY motivated, thank God.  Last year I was hitting it pretty hard with the car.  Over the winter we bought  piece of property that is very remote and I've spent most of my free time there this year working on getting it to a livable condition.
Over the winter my GTR was taken apart after the 8.60@164.8 mph run last fall on a set of Xona Rotor Reds, stock turbo fold turbos.
While it was apart we did a fresh 3.8 liter short block, freshened up the BR ported cylinder heads, swapped the 264 cams to 272's, added our billet front differential housing and then I contact Bill at SIR to see if we could work together on some turbos.  The Xona Rotor Reds certainly served me well but I wanted something "different".  Bill agreed, I sent the turbo to him and he took my new Xona Rotor Reds apart, used the cast compressor cover and built some new 58mm inducer bore turbos for me.
When the spring came and I drove the car it felt excellent, first pull on the street the car shut down a STFT had exceeded 120%.  I threw 30% more fuel to the VE table and gave it another hit, it pulled, I checked, everything looked good, called it a day.  I drove the car to dinner, ice cream stands and a few cruise in car shows.  I never dyno'd it.  I was busy with other projects.........
The car was set on 0% WGDC.
We took the car to the Shootout, I kicked myself in the ass all weekend as nothing seemed to go well.  Pushed too hard in the corners on the autocross course, braking sucked from some other mods I had done, then the drag strip came up and it was RWD, then we lost a solenoid in the trans and I was fed up.  Jack and Kevin from Jacks Transmissions pulled my car into their trailer, dropped the valve body, repaired the solenoid, re-assembled it and I was ready for Friday.....NO CHARGE I might add and it had nothing to do with either of them, great company and guys to work with.
Next day, still RWD, seemed to be having an AWD controller issue.  FINALLY the last pass, with some programming from John Visconti to help me out, it hooked, bogged down and ran an 8.95 at 163.x mph.
Flash forward, I got busy again, not that interested in running it, then started to think, "winter is coming, probably should do something to boost sales before the long cold slow down for winter."
Last Friday we returned to the track.  Still running 0% WGDC, which was giving me right at 30.xx psi.  First pass we clicked off a 8.491 at only 161.xx mph.  I wasn't too pleased.  I got greedy and started messing with the car and it was crowded, so I was making way too many changes at once and I know better.  So the 8.49 was the best pass of the night, I did accomplish getting my NHRA license testing all done though.
We got the car in here, swapped the street tires back and got it on the dyno today.
First pull at 30 psi was 930 whp.  Best pull ever was about 910 at 33 psi previously on the old set up.  The VE table stayed perfect so it was a matter of a few extremely small timing adjustments and working the WGC table.
In the end, at 35.xx psi of boost, the car put down an incredible 1044 whp and 768 ft lbs.  I pulled the car to 8200 where it is still climbing at nearly a 45 degree angle!
I'm excited to get back out to the track now.  The car is up over 100 whp from where it was last week.  My goal has been 8.20's at 170 mph and with these numbers if I can get it down the track decent it should be more than achievable.
Below are a few dyno sheets to show the progress of this project.
1st sheet is the current power level VS stock, 11.1 @ 122
2nd sheet is the current power level VS our BR140 kit which ran 10.1 @132
3rd sheet is the current power level VS the Xona Rotor Reds that ran 8.60 at 164.8
4th is the current power level by itself.   With 100 LESS HP than this chart shows it ran 8.491 at 161.
  • Tim, gtr34, Evolunchbox and 4 others like this
www.buschurracing.com
Standing 1/2 mile 199.29 mph
BUSCHUR RACING on FACEBOOK
BR SHOOTOUT on FACEBOOK
Buschur Racing
Buschur Racing
  • 2,360 posts
Turn your head sideways, they weren't like that when I posted them! haha
  • awdtt likes this
  • 9,757 posts
Damm Davis Nice work ..hope you get your 8:20
  • Buschur Racing likes this
Buschur Racing
Buschur Racing
  • 2,360 posts
  • Tim, Evolunchbox, Dan_585 and 1 other like this
Evolunchbox
Evolunchbox
  • 856 posts
  • Joined 19-June 13
  • LocationPittsburgh
Nice job, brother! Praying for nice weather Friday and I'll be over with my car. Let's go make some passes!
  • gtr34 and Buschur Racing like this
Buschur Racing
Buschur Racing
  • 2,360 posts
I'll get the car washed up and be ready!
  • Evolunchbox likes this
  • 3,910 posts
  • LocationOmaha
I'm a little dizzy from holding my head sideways while analyzing all those graphs, but I think you are selling yourself a bit short. The video shows 1058 whp and 775 wtq.
Bill@SiR
Bill@SiR
  • 476 posts
  • LocationMiami FL
Very cool.
The Dynos look great.  Guess my +100hp estimate was a bit conservative!
Buschur Racing
Buschur Racing
  • 2,360 posts
Very cool.
Estimate was low! These are still gaining power with more boost too. Also power is still climbing hard at 8200.. I think this ole GTR may just run decent!
OMG RB 26
OMG RB 26
  • 781 posts
  • Joined 07-May 14
  • LocationPeoria, IL
nice work!
2009 GTR - Self Built 3.8, Elite Plus, Self Built Trans (1K equivalent) E85  etc
1/4 Mile - 8.8@164mph
1/2 Mile - 201mph
nnas
nnas
  • 113 posts
  • Joined 21-March 16
that Vr38 starts to sound so exotic when it goes over 7000 rpms
GTR272
GTR272
  • 47 posts
  • Joined 13-August 15
What fuel system?
Buschur Racing
Buschur Racing
  • 2,360 posts
What fuel system?
The car has a twin 485 pump kit I built and intended to market, just haven't got around to it yet, stock lines, BR fuel rails, BR flex fuel kit and BR2150's.
VR_power
VR_power
  • 1,044 posts
  • Joined 05-January 15
1k on the BR dyno is going to move. That thing always seemed to read low figures compared to the times your car has done.
I see you managed a 1.2 60' is that still on 17" wheels? You have that launch dialed in great
Edited by VR_power, 30 September 2016 - 08:00 AM.
Also tagged with one or more of these keywords: buschur racing, sir, cobb, flex fuel, bfic
