2013 Boost Logic 2000 GTR
3 replies to this topic
360exotics
360exotics
  • 5 posts
  • Joined 28-May 16
​2013 Boost Logic 2000 GTR
Please give me a call if you have any questions.
Chris
512-944-9974
http://www.360exotic....-austin-texas/
Up for sale is a 2013 Boost Logic built GTR that is capable of over 2000 whp ( has made 1773 on the dyno with plenty of boost left to go ) this car has been built by one of the best GTR builders in the world and no expense has been spared. The car is like new, in near perfect shape, and has never been in any accidentsand has a clean carfax.
This car has been built to be a daily driver, run a 7 sec 1/4 mile, or run 215 mph plus on the 1/2 mile. The car was built with 2 things in mind, to be competitive in any event on the planet and do it while maintaining reliability and comfortability of the GTR. This GTR makes 1000 hp pn just pump 93 octane. The build quality and the amount of work that was put into designing this car is mind blowing with all the custom parts and time that was taken to assemble this beast.
The build started from scratch with a completely stock car with 4500 miles on the odometer ( currently 5337 ) less than 1000 miles on the entire build. The car was just re inspected completely by Boost Logic and given a good bill of health ready for the new owner to go out and break some records.
ENGINE
-Boost Logic Built 4.1 Stroker Short block w/ Custom Boost Logic spec Sonny Bryant crank
-Custom Block and Oil System Treatments
-Boost Logic Custom Rods
-Boost Logic Upgraded Promod Wrist Pins
-Boost Logic Spec Custom Piston Set w/ Upgraded Rings
-Custom Main Studs
-Boost Logic Oil Cooler Kit
-Boost Logic Race Intercooler Kit w/ Piping
-Boost Logic Crank Damper
-Boost Logic 4″ Exhaust System w/ Electronic Dumps
-Boost Logic Coolant Tank
-Boost Logic Intake Manifold
BOOSTLOGIC STAGE 4 HEAD PACKAGE INCLUDES
-Ported Heads
-Ferrea Valvetrain Components
-Boost Logic Custom Spec Camshafts
-Custom made Boost logic catch can to fit In the battery location with a drain tube that drains out the bottom of the wheel well.
TRANSMISSION AND DRIVELINE COMPONENTS
-T1 Differential Brace
-T1 Deep Billet Transmission Pan
-Boost logic solid engine and trans mounts
-Driveshaft shop front and rear race axles
SHEP STAGE 4.5 TRANSMISSION INCLUDES
-PPG Extreme Gearset (new updated version)
-Dodson Pro Max clutch/Alloy version 12/12
-PPG Billet front and rear drop gears
-Dodson Heavy Duty clutch springs
-Dodson Piston shaft seals
-Dodson FWD retainer
-Dodson Mechanical locks
-Dodson Oil pump shaft upgrade with blueprint
-6 neodymium magnets
-Dodson High temp rear differential seals
-Dodson Fwd output seals and shafts
-Dodson thrust bearing circlips
-Arp Rear diff bolt upgrade
-Dodson Surge/Baffle kit
FUEL SYSTEM
-Boost Logic Mechanical fuel pump that includes the factory dual in-tank pump setup guarantees a prime on the mechanical pump and proper balance in the fuel tank
-6 custom 2450cc primary injectors
-custom Boost Logic 3rd fuel rail with a 2nd set of 1000cc injectors
ECU & TUNING
-Motec M1 ecu tuned by Chris Black
WHEELS AND TIRES
-Volk TE 37 SL’S
-18×9 frt with M&H 275/45/18
-18×11 rears with M&H 325/40/18
-BL/ Bogart 15″ beadlock drag packs
-MT Et street 325/50/R15
SUSPENSION
-Penske full drag suspension
-15″ Wheels conversion
BRAKES
-AP racing J hooks
-Endless pads
-BL/Willwood rear drag brakes
INTERIOR
-Titan bolt in roll bar
MISC
-Stroud parachute kit
  • Tim and droptopp like this
  • 9,928 posts
Sweet ass ride,and the tuner knows his shit!!! GLWS
360exotics
360exotics
  • 5 posts
  • Joined 28-May 16
Bump.
This  car is still forsale.
Chris
512-944-9974
  • cmurder1019 likes this
Guido
Guido
  • 320 posts
  • Joined 05-January 13
That is one sweet ass car!  Amazing build.  GLWS. :)
