2009 Nissan T1R Alpha 20 GTR
6 replies to this topic
360exotics
360exotics
  • 5 posts
  • Joined 28-May 16
Please let me know what questions you have.
Chris
512-944-9974
http://www.360exotic....-austin-texas/
360 Exotics is proud to offer you the ONLY customer owned Alpha 20 in the country, with less than 200 miles on the build. This car has been built and maintained by arguably the best shop in the world and is the same shop that built the cars that hold the ET and trap speed GTR records for the world! The first thing to know about this car is it WASNT built to be just a race car, this car was built to be driven on the street with all the street manners possible and all the factory functions as well, but also built to dominate any race it enters. This car has only the very best componets built by one of the best shops ( T1 Race ) in the world. No expense has been spared with this build and you will not find one in the world to be able to compare it to. As we will attempt to list all of the modifications on this car, some will intentionally be left out as they are not intended to be displayed to the public. This car has always been maintained by T1 and has been stored in a climate controlled facility its while life. Any serious inquiries will be directed to Tony at T1 race to answer any additional questions as im sure he will still want to service and care for this car when the new owner takes delivery.
Power levels and tuned fuels
-E85 = 1500hp
-VP Import = 1800hp
-power levels are at 41 psi
Engine
-GT1R Stage 4 extreme duty short block
-GT1R 4.1L stroker kit with SBR crank
-GT1R fully balanced and blueprinted rotating assembly
-GT1R spec head and main stud kit
-GT1R CNC ported and polished cylinder heads W/ 3 angle valve job
-GT1R CNC Kelford man cams
-Ferrea high pressure valve springs
-Oversized SS valves
-Titanium retainers
-Spring locators
-Bronze valve guides
-OEM nissan gasket kit
-GT1R sumped oil pan
-GT1R crank case ventilation system W/ wrinkle black powder coated option
-GT1R Air/ oil separator kit
-GT1R harmonic damper
-fully powered coated valve covers, timing covers, and upper and lower intakes
Turbo kit
-AMS Alpha 20 turbo kit
-Driven innovations air to air intercooler
-GT1R custom intake system for Alpha 20 turbo kit
-GT1R spec blow off valve for Alpha 20 turbo kit
GT1R stage 4 Fuel system
-GT1R tripple pump system
-Gt1R 12 injector fuel rails
-6 x ID1300 cc primary injectors
-6 x ID2000 cc secondary injectors
Engine management
-Motec M1 ECu
-GT1R spec harness kit
-GT1R spec injection harness kit
Drivetrain
-Shep trans stage 4 transmission
-PPG 1-6 gear set
-custom step/ dodson 12 plate promax
-GT1R differential braces
-Drive shaft shop pro level rear axle kit
-GT1R transmission overflow kit
Exhaust
-GT1R custom 4″ with secondary dumps
Wheels & Tires
-19″ Front Forgeline GA3R wheels
-19″ Front Michelan Pilot sport tires
-18″ Rear Forge line GA3R Wheels
-18″ Rear Micky Thompson ET street tires
Brakes & Suspension
-R35 Brembo Carbon ceramic brake package frt and rear
-Carbo tech brake pads
-Eibach lowering kit
Misc
-Full Expel clear bra
-Full interior and trun sound deadening
-Front and Rear view camera system
-Ctek battery with build in charger                ​
  • Tim, ghostrider and droptopp like this
  • 9,906 posts
Somebody is gonna get a deal on this 1. Shin was meticulous with this car. I am defy peanut butter and jelly about this car.
  • 4,594 posts
I think 7racer should just buy this and keep his other car for the track.
  • Tim and elf_cruiser like this
  • 9,906 posts
^^^^ I agree
Guido
Guido
  • 314 posts
  • Joined 05-January 13
How much?
  • 9,906 posts
[quote name="Guido" post="130623" timestamp="1508393915"]
How much?[/quote
This was sold a guy named Jeff H out of Carolina owns it now cool dude with a couple of cool cars
Guido
Guido
  • 314 posts
That's fine, but how much was he selling it for?
