**Boostin Performance Stage 3 Short Block Package**
42 replies to this topic
Boostin Performance
Boostin Performance
  • 856 posts
  • Joined 09-October 15
  • LocationHoffman Estates, IL
Are you ready to take your GT-R to the next level?  Or are you looking to do a rebuild, or in the middle of a rebuild and looking to build a solid foundation?  Look no further!  Our Boostin Performance Stage 3 Short Block Package will give you a stout lower end that will be ready for whatever you throw at it!  From mild to wild, every GT-R can benefit from a Boostin built short block!
All Boostin Performance Short Blocks are built upon request, using your supplied core.  Your core block is decked and honed, and we install ARP Main Studs, and the block is line honed to our exact specs.  The rotating assembly is balanced before installation to ensure your motor is ready to handle hi-revving demands.
Check out our website for more information or to place your order!
http://shop.boostinp...short-block.htm
Engine Packages Include:
-Labor to machine block/crank
-Labor to tear down/build short block
-BP spec. I Beam Rods
-BP spec. Pistons
-Coated Engine Bearings
-ARP Main Studs
-Balanced and Blueprinted Rotating Assembly
Feel free to stop by the shop or send us an email or call with questions.   :thumbsup:
847-781-1600
BoostinPerformance@gmail.com
Boostin Performance
(847) 781-1600
http://Shop.BoostinPerformance.com
7.2 @ 203 MPH!
**HOME OF THE QUICKEST & FASTEST ALPHA 16 **  7.54 @ 192MPH
We also hold the ALPHA 12 & 10 ET Records too!
Boostin Performance
Boostin Performance
  • 856 posts
Motor Monday Bump!!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
TTT!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Boostin Bump!!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Post-shootout Bump!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Mid-week Motor Bump!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Starting to plan your winter build?  Let us help you build the foundation needed to handle all of your horsepower goals!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
This engine package powered us into 7's! Contact us today to build yours!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Boostin Bump!!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Boostin Bump!!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Planning out your winter build?  Don't hesitate to contact us for all your engine building needs!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
To The Top!  It's Motor Monday!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
#MotorMonday !
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Wankeldude
Wankeldude
  • 167 posts
core block bores are honed?  so do you re-apply plasma liner after?
V8killer
V8killer
  • 213 posts
  • Joined 05-March 14
I would assume they are probably referring to a slight hone to seat the rings and line hone for the mains after installing studs.
  • 2,855 posts
You can take a couple thousandths off the cylinder walls without getting through the plasma but it's best not to.
Wankeldude
Wankeldude
  • 167 posts
It's less than 6 thou thick to begin with. Any scratch at all would be too deep to hone. Isn't sleeving or fresh new block the only answer unless you've got access to PTWA lining facility?
Edited by Wankeldude, 10 January 2017 - 01:08 AM.
Boostin Performance
Boostin Performance
  • 856 posts
 All of the blocks are kept standard bore.  Only a very light honing is done, so this layer is unaffected and still present.
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Contact us for all of your motor building needs. We're here to tackle it all!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
Boostin Performance
Boostin Performance
  • 856 posts
Boostin Bump!
Boostin Performance
(847) 781-1600
7.2 @ 203 MPH!
