Bearing and Clearance Recommendations
31 replies to this topic
  • 3,909 posts
  • LocationOmaha
I just noticed that Bill@SIR, back on April 16th, in the first response to this post, said the same damn thing that I tried all day to get you to absorb.  So I'm relieved to hear that we've finally made the breakthrough!
changster
changster
  • 2,302 posts
  • Joined 26-January 13
  • LocationBay Area + Taipei
If you were a shop you could learn on customer builds and customer money, then see if they blow up. Too bad you don't have that luxury. :)
KNOTZLA
KNOTZLA
  • 360 posts
  • Joined 17-March 13
Who did you wrong?!
changster
changster
  • 2,302 posts
Who did you wrong?!
Nobody. Just messin' around. :)
colo_evo
colo_evo
  • 97 posts
  • Joined 20-September 16
How did this work out Parker? Surely the engine is together and has sufficient run time on it by now.
I'm sizing bearings now and am aiming for 0.0009" for mains. Nissan spec if using only crank and block markings puts my oil clearance at 0.00067".
EDIT: 0.0009 according to the bearing matrix.
Attached File  Bearing matrix.PDF   125.96KB   18 downloads
Edited by colo_evo, 08 November 2018 - 08:22 PM.
Bill@SiR
Bill@SiR
  • 466 posts
  • LocationMiami FL
Just saw this on the Bump. LOL  Good times
You might want to actually get a block, bearings and a crank and measure it.  In general the OEM runs around the middle of the spec, Generally in the 1.5-1.7 range on the mains if you measure an OEM engine.
I generally would go towards the higher end of the spec for more power.  But to be perfectly honest If your trying to make 1000+ HP I would just get a block from a repeatable company.  They did the R&D (im not talking about SBD Rip off and Duplicate) And unless you want to learn the expensive way its best to just pay.
colo_evo
colo_evo
  • 97 posts
I appreciate your suggestion of going with a proven company Bill but I'll be assembling the engine myself. I've got plenty of experience and resources to complete the job.
Here's what the ESM has for clearances. I can see where the confusion is in the matrix mentioned early in the thread. Looks like the matrix gives you clearance per bearing. You need to multiply by 2 to get total clearance, or what's actually measured after installing bearings and checking against the crank journals.
Here's what the ESM has for clearances:
MAIN BEARING OIL CLEARANCE
Unit: mm (in) Items Standard Limit Main bearing oil clearance 0.035 - 0.045 (0.0014 - 0.0018)* 0.065 (0.0026) *: Actual clearance
CONNECTING ROD BEARING OIL CLEARANCE
Unit: mm (in) Items Standard Limit Connecting rod bearing oil clearance 0.055 - 0.068 (0.0022 - 0.0027)*
0.088 (0.0035)
*: Actual clearance
Bill@SiR
Bill@SiR
  • 466 posts
  • LocationMiami FL
0.088 (0.0035)
*: Actual clearance
So you have OEM rods?
OEM Main Studs?
OEM Crank and OEM Block with OEM hardware you can use the chart if you wish, I would highly suggest measuring for like the 10th time because of tolerances that your shooting for are in the tenths of thousands of inches, and dealing with 3 different tolerances, (Crank, Block and Bearing) even though they are OEM.  You will get in the range, isnt that precise in the real world.   But when you make more power, I would recommend  tolerancing the motor to a more precise level.
Vanilla
Vanilla
  • 21 posts
  • Joined 01-November 18
i am also in the process of gathering all parts / information I need to build the engine and am still on the fence whether to use stock Nissan bearings or King Race bearings. I have ordered both but I am leaning towards the "save" option of Nissan bearings. My power goal is 850whp with efr 6758 hybrids on 102 octane gas (95RON), so nothing over the top.
colo_evo
colo_evo
  • 97 posts
OEM Main Studs?
Just to be clear I'm only using the matrix to get my first set of bearings. After that I'll take actual measurements with a dial bore gauge and micrometer then replace bearings to achieve desired clearances. I'm not suggesting the matrix is a replacement for actually measuring.
I'm using stock crank, stock hardware and manley rods. Manley's suggestion is 0.002-0.003" with no trailing zero. ESM goes out to the forth significant figure. Both target around 0.0025" as far as I can tell
Depending on how my initial measurements look I'll order up different bearings. I'll probably target somewhere between the high standard and maximum; 0.0019" for mains and 0.0027" for rods.
I'll update this thread or possibly start my own build thread after I actually start the assembly.
colo_evo
colo_evo
  • 97 posts
These are the mains I pulled out. Unfortunately I sold and shipped my block before I was able to take the measurements. I hope my new set wears better than these. Engine had under 20k and was previously built.
Rods looked much better than the mains.
Vanilla
Vanilla
  • 21 posts
so those bearings came out of a built engine with 20k miles? how much hp did you run through it?
yea would've been really interesting what clearances they had.
