DSC / Tractive electronic shocks / controller.
119 replies to this topic
#101
as far as I know
#102
  • 835 posts
It’s not available for the GTR unfortunately as far as I know, not even the lift kit.
Edited by BAZ007, 27 November 2017 - 09:33 PM.
#103
mikelmarion
mikelmarion
  • 240 posts
  • Joined 31-March 17
Any updates on the launch programming? Or any custom Gtr settings?
#104
  • 835 posts
I will hopefully have my car back in 3 weeks and be able to test the fuck out if it.
  • elf_cruiser and mikelmarion like this
#105
mikelmarion
mikelmarion
  • 240 posts
Finally lol
#106
3RotorRX7
3RotorRX7
  • 5 posts
  • Joined 14-February 15
I have been racing on these successfully for a year in SCCA Pro Solo using 1700lb front springs and 650lb rear springs, and would be willing to share my maps that have been adapted from the stock maps.  PM me offline and I will share my map.
Erik
  • forty-two, thehelix112, elf_cruiser and 1 other like this
#107
  • 4,584 posts
Erik
Cool!
Would also settle for driving impressions?
  • mikelmarion likes this
#108
  • 756 posts
Erik
Thumbs up for a local owner, & really nice guy!
  • 7racer, elf_cruiser and mikelmarion like this
#109
3RotorRX7
3RotorRX7
  • 5 posts
Cool!
It's really nice to be able to set valving for very high spring rates, have a setting that dials down the harshness, and another setting to change on the fly to see if you can find something better.  Not only do I play with settings at the track, but on the street to feel the differences, by switching between the settings back and forth quickly while driving.  Can't compare this to turning  knobs...
  • thehelix112 and mikelmarion like this
#110
  • 4,584 posts
Hmm can you speak more about the change on the fly piece here? My understanding was the only way to tune the dampers was with a laptop and their software?
#111
  • 1,662 posts
I think he is talking about the controller with buttons like 7racer has. Otherwise you could program your Comfort, Normal, and Race as 3 distinct maps and switch between the 3 as you drive.
#112
  • 4,584 posts
Ahhh gotcha. That makes sense.
#113
3RotorRX7
3RotorRX7
  • 5 posts
Yes, that's what I am doing.
#114
jdmrb1
jdmrb1
  • 380 posts
  • Joined 22-February 15
  • LocationYokohama Japan
DRK any updates. Need these coil overs real bad.
#115
jdmrb1
jdmrb1
  • 380 posts
I decided to run the Aragosta Type SA which has PnP so it can be controlled with OEM or DSC box with the 4 cup lift kit !
  • 7racer, choerizo and BAZ007 like this
#116
  • 835 posts
Would be awesome to hear your feedback on those compared to what I will be runing. Exact same thing but Tractive vs Aragosta!
I initially was going the Aragosta route btw. But wanted to try the new technology in the Tractive!
#117
Baz, I cant remember, you are going to run it with the DSC correct?
#118
  • 835 posts
Yes, I also have them equipped with Umbrellas (Ravi's) 4 wheel lift system. Since Tractive decided to offer their lift system for the Porsches (only front wheels) and not the GTR nor they have plans to offer them for the GTR.
Umbrella system is sweet though, I tried it few times and the lift is quite remarkable!
I am not Shawn/Ehy/7 to properly push the suspension system to the max, however the primary promoted advantage of the tractive suspension is their patent for the electronically controlled Dynamic Dampening Adjustment which allows both Rebound and Compression functions to utilize the same hydraulic channel as opposed to having a separate channel for each function. Moreover, being electronically controlled vs mechanically controlled as a function of pressure makes the adjustments achieved in a much quicker time and more precise.
I know that Tractive company does alot of development for top suspension companies including Aragosta. I also believe the ACE controller that Aragosta uses might be developed by Tractive. Additionally combining Tractive and DSC ECU should, in theory, make for one bad ass combination that makes it all digitally controlled and easily tuned + Suspension R switch compatibility and Launche mode!
Edited by BAZ007, 10 May 2018 - 07:11 PM.
  • thehelix112, shawnhayes, choerizo and 1 other like this
#119
jdmrb1
jdmrb1
  • 380 posts
Aragosta lift system with Type SA PnP which works with OEM or DSC controller box. 16/10 spring rates!
Edited by jdmrb1, 10 May 2018 - 10:44 PM.
  • 7racer and choerizo like this
#120
jdmrb1
jdmrb1
  • 380 posts
Finally ordering this setup! Pics to follow, need new dampers so bad!
