New Mobil-1 0w-40
* * * * - 2 votes oil
64 replies to this topic
#61
  • 7,280 posts
that's a pretty big difference.
#62
  • 4,800 posts
New FS is a superb street oil, and if kept cool, should be a great GT-R oil.
HOWEVER, lets say you go, oh, I don't know, Circuit of the Americas? Maybe?
A 16% drop at high temp (which I see all the time) is SIGNIFICANT.  I MAY give this oil a try after I exhaust my supply of Redline 0W-40, but I don't have an accessory oil cooler (like my good friend, descartesfool).  The prior formulas didn't fare as well with my heavy hot track use.
#63
Kevin_E
Kevin_E
  • 55 posts
  • Joined 02-November 15
  • LocationAZ/GA
Definitely keep us posted. I still have some miles to go with the blend I tried out. Curious to see how the report plays out with this sample.
Kevin
#64
Sleepyrx
Sleepyrx
  • 19 posts
  • Joined 25-April 16
I'm really interested to see how it turns out. I still have 7 jugs + 4 quarts (and an open quart), after just doing my 2nd oil change since the discontinuation, recently.
If it turns out to be significantly better for the engine, I might just have to swap over to the FS, way sooner than expected. Although it would have been about 4yrs, before I ran out of the "old formulation" and started FS. It's cheap enough, that even if I couldn't swap it with someone, I'd still switch to FS when the next oil change came around.
#65
twinturbogodzilla
twinturbogodzilla
  • 3 posts
  • Joined 18-September 17
2017 owners manual still says Mobil 1 0-40w .
"Mobil 1 (0W-40) (100% synthetic) is the factory fill oil. The VR38 engine with its plasma-sprayed bores was developed using this oil. NISSAN cannot ensure proper engine operation and durability if other 0W-40 synthetic oil is used. If Mobil 1 (0W- 40) is not available, Mobil 1 (10W- 40) (100% synthetic) may be used; however, some performance loss may be noticed."
Also tagged with one or more of these keywords: oil
