My planned build - blend of HPDE and weekend drives
- - - - - build hpde
thebeast
thebeast
  • 43 posts
  • Joined 01-January 16
Thank you for all your posts … it's been great soaking it all in over the last couple months ... awesome information
Goal: balance between HPDE and weekend drives with my wife and daughter
Car: 2014 DBA Black Edition (purchase delayed to Fall '16)
Engine/Tuning: stock
Transmission: stock
     (upgrades to be added when maintenance is needed)
     Shep Stage 1
     T1 Upper and Lower Brace Set
     T1 Overflow Catch Can
     Dodson Anti Surge Plate Kit
     Dodson Pan Magnet Kit
Brakes
     Revozport front lip with air ducts
     Titek front diffuser support brackets
     600 Degree Aircraft Silicone Ducting
     Front rotor dust shields with hose adapter
     Rexpeed or Dodson Brake Cooling Guides
     Stillen Rear Brake Cooling Kit
     RB 390/390 Light wt replacement rotors
     RB upgraded middle mounting bolts
     RB stainless steel brake lines
     Speedbleeders - stainless
     Castrol SRF brake fluid
     Street - RB ET500 brake pads
     Track - RB XR70 brack pads
Cooling
     HKS transmission cooler
     Willall Front Differential Cooler
     Willall Rear Differential Cooler
     Dodson Rear Differential Scoop (?)
     AMS Alpha oil cooler (purchased)
     Dodson Engine Oil Cooler Temp Switch (85C deg)
     Forge power steering cooler (?)
     Spec V coolant tank and 180kpa coolant cap
     Forge Motorsport Silicone Coolant Hose Kit
     Dodson Engine Coolant Temp Switch (68C deg)
     RedLine WaterWetter
Engine
     Buschur Racing oil catch pro can
     AMS Cowl Splash Shield
     Motul 300V (15W50)
     Nismo oil filters
Exterior
     Top Secret wide front fenders
     Stillen front license plate holder
     Front and Rear tow hooks
     Underbody SS hardware kit
     Xpel clear bra (cover as much of car as $ will allow)
Interior
     GotBoost fire extinguisher mount
     Schroth 4 point harness
     Forged Performance Steering Column Reinforcement Plates
     Valentine One mirror mount/direct wire
Suspension
     SPL PRO adjustable front upper arms (if needed)
Tires
     Street - Michelin Pilot Super Sport (MPSS) (335/30ZR20)
     Track - Nitto NT-01 (335/30ZR18)
     Nitogen (via welding supply bottle)
Wheels
     Street - OEM Black Edition 20x10.5 +25 - square
     Track - Volk Racing ZE40 18x12 +20 - square
     MCR or Wheelspacers.ca 5mm spacers in the front (if needed)
     ARP Studs (length to be determined)
     Muteki SR48 lug nuts
Trailer
     Dave's trailer hitch
     Customized Harbor Freight 48”x96” 1720 lb capacity trailer (custom work in progress)
Tools
     QuickJack BL-5000XL Car Jack Support System
     Giro Disc Piston Spreader
     Brembo Caliper Pad Pin Punch
Areo
     APR Front canards
     APR GTC-500 rear wing
     Willall Trunk Supports
Edited by thebeast, 25 May 2016 - 02:40 PM.
  • Tim, ian.r, bpauto and 1 other like this
  • 7,721 posts
that looks sweet!
one thing when I was looking at the list is the BL vs AMS oil cooler...I had the BL but while big, it didn't do that much to lower oil temps.
Other people have had the same results if you search threads about it.  The AMS seems much more effective.
  • ian.r and tgkb278 like this
  • 4,266 posts
Fucking bitchin build plan man. I'm glad you're local, gunna pick your brain as we go!
  • tgkb278 and thebeast like this
tgkb278
tgkb278
  • 416 posts
  • Joined 09-February 14
  • LocationBack to CA
Congratulation on getting the car and welcome to Heritage.
Since I didn't see any power mod listed, I am going to assume that you plan to stay with stock powertrain and stock tune. So all my comment is going to reflect that, things will change if you add more power.
Brake:
Front brake cooling is a must
Rear brake cooling depends on how often you track and drive the car, consider the kit can cost more then a set of rear pads, you have to think in turn of cost vs pad and rotor wear saving. If you plan to track more then once a month, I think it is worth it.
Powertrain cooling
Transmission cooler is a must, coolant tank is worthy and inexpensive upgrade.
Upgrading stock oil cooler and diff cooler probably won't be necessary until you add more power. Quite a few of my GTR track friends reported normal track fluid temps with only the transmission cooler. I think is it cheaper to change the engine oil and diff fluid more often then getting the cooler.
I just wrap a sports headband over my steering fluid reservoir.
Engine:
Got Boost catch can, but I am bias
Exterior
Clear bra the whole car, I did front half of the car and my rear quarter panel is all dinged up.
If you are on Facebook, let me know. We usually coordinate track days on So-Cal GTR group. The next track event for the group is on Feb 20th with Speed Ventures at Fontana ACS.
Tony
Edited by tgkb278, 31 January 2016 - 02:23 PM.
  • 7racer and awdtt like this
awesome build thread so far. I'd recommend the Boucher pro catch can or similar with connection to the oil cap for crank case. he did a lot of research into the topic (as did the others before him, but he shared the results with us all). I assume the gotboost cans can be modified to work the same.
for brake ducts you could start with the spatula mod and temp paint... then upgrade from there if needed. part of the fun of racing is tracking the data and making sure everything is in check!
for trans, basic preventative build would be idea, pick Shep's brain about what would be idea for your spec and how many times a year your going to race. I would imagine first gear, circlip, clutch and baskets.
also read all of ehymans posts. example http://www.gtrherita...e-installation/
I agree with everything these guys said above too.
thebeast
thebeast
  • 43 posts
Thanks guys - great feedback
I made a few updates above ... and cleaned it up a bit
and a couple open questions ...
 - Front Canards ... how much benefit at stock power level?
 - Larger Rear Wing ... how much benefit at stock power level?
Edited by thebeast, 01 February 2016 - 02:15 AM.
  • 1,625 posts
Larger rear wing you will feel most under hard braking.. At least that's where I think it makes the most difference.
  • 7,721 posts
I would say that since you are leaving suspension (coils) and engine stock, that you can hold off the aero.
I do think it helps but for me it's been subtle.  More noticeable when I go back to a stock car.  The magic about the GT-R is the amount of mechanical grip.  With the mods you listed you are already going to be lapping 90% of the field.
suspension like ehyman suggests and a bit more power and I think aero will start coming into play much more.
  • 7,721 posts
oh and with my active rear wing, braking was the most noticeable difference right off the bat.
I think I have been too chicken to carry speed in corners with my aero :P
  • 7,721 posts
Hey beast, BPauto is having a 20% off sale...probably pick up the trans cooler for a good deal!
  • bpauto likes this
bpauto
bpauto
  • 570 posts
Yessir, feel free to contact us if you're in need!
Also, if you have any other random GT-R questions, feel free to reach out. I'd be glad to help!
thebeast
thebeast
  • 43 posts
thanks 7racer! ... pm sent
Also tagged with one or more of these keywords: build, hpde
