Weird ethanol content reading
16 replies to this topic
BOOSTIN-B
BOOSTIN-B
  • 170 posts
  • Joined 25-June 14
So, Visconti FF kit about 4 months old.
Car starts sometimes and the ethanol reading says super low , in the mid 20's when the content is in the high 60's or low 70's
After about 1 minute it gets the correct E content and all is well from then on.
Anyone had this issue. Doesn't happen all the time just very random.
NickTO
NickTO
  • 2,184 posts
  • Joined 29-December 12
Try jiggle the fuel line hose barbs on either side of the sensor with your fingers (not hard) and see if that makes the reading jump.
Otherwise make sure connectors are seated properly.
GT-R Heritage MAKES AMERICA GREAT AGAIN!
NICK YOUR A FUNNY FUCKER DUDE  :D   - TIM 2015 & 2016.  2 Years Running!
ThatOtherGTR
ThatOtherGTR
  • 174 posts
  • Joined 02-September 14
Is this only when the car is heatsoaked and has been shut off for a little while? Possibly the ethanol in the return is boiling if it gets too hot?
Mine does this. It's a gotboost kit. It has only done it for the last few months. I am on cobb and it possible it is also a code issue or sensor issue.
NickTO
NickTO
  • 2,184 posts
If you get heatsoaked and the ethanol reaches near flash point, the GotBoost kit would blink the LED rapidly while the temp is high.  Do you get that happening?
BOOSTIN-B
BOOSTIN-B
  • 170 posts
  • Joined 25-June 14
This is cold or hot. Doesn't have a pattern there.
It super hard to try to move the lines because when you get in the car you don't know if it's going to do it or not and by the time it's done it you can't get under the hood fast enough.
Seem like a sensor failure to me. Hopefully Visconti will chime in on this
Ian201
Ian201
  • 121 posts
  • Joined 28-September 14
  • LocationStenungsund Sweden
If your running EcuTek you can also check the content on the coolant temp gauge before starting and compare.
  • 7,777 posts
interesting...
BOOSTIN-B
BOOSTIN-B
  • 170 posts
  • Joined 25-June 14
On Cobb.
  • 535 posts
How about letting the fuel pump run for a few seconds before starting the car to flush the lines and sensor with fresh fuel?
ThatOtherGTR
ThatOtherGTR
  • 174 posts
Not that I can recall. Maybe once or twice, but not every time it happens. But fuel pressure is fine according to cobb. I don't have an issue with pressure dropping after I shut off, at least not for a long while. I just assumed it was because of that. It's always in the 25-50 minute time frame after shutdown. Immediate restart never fails and over an hour after shutoff never fails.
Though I do see the ethanol content fluctuate sometimes when it happens. But it seems to do it sometimes on a perfect start also. This led me to adjust some of the new cobb features to keep ethanol content stable while cranking. And it still fluctuates occasionally according to cobb.
Edited by ThatOtherGTR, 27 November 2015 - 05:58 PM.
ThatOtherGTR
ThatOtherGTR
  • 174 posts
Do you have your fuel pumps hardwired? What pump setup, etc.?
ThatOtherGTR
ThatOtherGTR
  • 174 posts
Also, sometimes I know it's going to do it (25-50 minutes time frame after shutdown), so I attempt to prime the pumps first...and I get nothing. Not always, but occasionally I don't hear anything when I prime the pumps. Almost as if cobb glitches out on the priming part. The pumps are good and the wiring is all good and solid.
BOOSTIN-B
BOOSTIN-B
  • 170 posts
  • Joined 25-June 14
Fuel pumps are hard wired Dual 450 walbros
My fuel pressure reads normal during this period as well
haseeb
haseeb
  • 4 posts
  • Joined 11-April 17
So what was the actual problem ??
Happening same with my car as well ..
mikeydiker
mikeydiker
  • 5 posts
  • Joined 09-April 16
How do you do that?
  • 9,629 posts
This should help ya
  • Ian201 likes this
240Z TwinTurbo
240Z TwinTurbo
  • 272 posts
  • Joined 06-February 14
If the flow through the ethanol sensor is low then it will provide a low reading.  You can place it after the fuel rail and before the fuel pressure regulator to see if this corrects the issue.  I placed mine away from the heat as some have suggested being over the exhaust affects the sensor performance.
DIY700 - 700hp on a Budget
