We have a Dodson 1st to 6th Extreme Duty Gear Set in stock and ready for an in-house install!
This is a complete 6 Speed Heavy Duty Gear Set. The helical gearset includes straight cut 3rd and 4th gears for added strength.
Dodson gear sets are made from Dodson's proprietary material. They are also heat treated and cryo treated to ensure maximum durability and minimal deformation and wear. They feature the following:
- Strengthened input shafts
- All gears ground matched for perfect contact and increased load capacity
- Optimized gear profiles for optimum strength and rigidity
- Increased bearing capacity
- Changeable/custom ratios available -TCM modifications required
This full kit Includes:
- 1 3 5 Input Shaft
- 2 4 6 Cluster Shaft
- 1st, 2nd, 3rd, 4th, 5th & 6th Gear
- 3rd & 5th Pinion Gear
- Spacer Washer
- Washer
- Heavy Load Shaft Bearing
- Locking Nut
- Billet Steel 6th Gear Selector Fork
- 6th Gear Selector Shaft
- R35 TBC2 135 Circlip
- R35 TBC2 246 Circlip
- R35 OSEF Shim
- R35 MC2
- R35 GL
