discuss tips on buying a tuned/built gtr.
30 replies to this topic
this seems to happen to a few people. they buy a tuned or built gtr and something goes wrong. let's help the community by adding tips on what to do, especially for those who are clueless (nothing wrong with that).
for instance... if you are driving the build back home across states ... make sure it has a 91oct tune. make sure to log it the whole trip. elevation changes throughout different states could change and be harmful. get gas from good stations to avoid bad gas.
-make sure you have data logs that are extremely recent.
-make sure a well known gtr shop has worked on it.
-make sure the hardware is what it is
-inspect the rear lsd for cracks.
-inspect the fluids.
-have it taken to a gtr shop to get inspected.
-check ic pipes for oil
-check all downpipe studs are there
-check the crank case pressure
-check the oil gally gasket is not blown
what other tips do shops and members recommend?
  • Tim, thehelix112, RobertBeive and 1 other like this
ATL_GT-R
ATL_GT-R
  • 695 posts
  • Joined 20-December 12
Most importantly, check the quality of the parts used.  Typically, people that skimp on parts do the same with maintenance and install quality.  Clearly not always the case but, generally, I think someone that is not afraid to invest in high quality has a stringer desire to care for that quality.
  • LTHL VNM and OuLikeBlueGTRs like this
C63s
Huracan Spyder
TSM l '10 Alpha12
'14 Midnight Opal
Xsuil
Xsuil
  • 357 posts
run it on a dyno to make sure it's making what is claimed lol .
Phase 1 :
- Topspeed Motorsports 4.0 Engine .
- ETS HTA 3794 Turbo Kit .
- 1460 HP @ 38 PSI
- 1100 HP @ 25 PSI
Phase 2 :
- Topspeed Motorsports 4.1 Engine .
- ETS Little Hero Super99 Turbo Kit .
- 1500+ HP @ 40 PSI
- 1000  HP @ 21 PSI
Phase 3 : In Progress
- T1 Race Development 3.8 Engine .
- DMS Custom Forward Facing Turbo Kit.
Xsuil
Xsuil
  • 357 posts
Stay away from " Custom " stuff .
unless you know who made it and a good quality piece .
Phase 1 :
- 1460 HP @ 38 PSI
- 1100 HP @ 25 PSI
Phase 2 :
- 1500+ HP @ 40 PSI
- 1000  HP @ 21 PSI
Tony1
Tony1
  • 931 posts
  • Joined 28-December 12
A reputable shop and high quality parts in the build are two things you do not want to deviate from.  They are make or break deals as far as I see it.
In regards to the original post, a few comments.
-inspect the rear lsd for cracks - this isn't really a reasonable thing to check, nor is it a common failure point.  It would be an expensive inspection.
-check ic pipes for oil - This doesn't really tell you anything other than if it needs some work in the breather department.  Doesn't necessarily indicate a problem.
-check the crank case pressure - This would need to be done on a dyno pull at high power to be meaningful.
-check the oil gally gasket is not blown -  This is not really reasonable to check either.  It's a ton of work pulling the front cover off an engine.
Things I would recommend doing:
Do an oil change and cut open the filter, look for signs of engine problems, bearing material or other in the filter.
Do a leakdown test on the engine.  It's a bit of work, but it's a great indicator of engine health.
  • Tim, ian.r, 7racer and 3 others like this
T1racedevelopment.com
Injectordynamics.com
214-607-9022
Jimefam
Jimefam
  • 523 posts
  • Joined 18-February 13
So what your saying tony is you don't magnaflux the stock crank prior to buying a car????
Tony1
Tony1
  • 931 posts
No, that I would definitely recommend.   Check the ring gaps too. lol
214-607-9022
  • 1,721 posts
Check for twine!
  • Tim and Doug@WGP like this
  • 1,938 posts
Check for twine!
That and also WHINE !!
What? Too soon?
  • Tim and choerizo like this
changster
changster
  • 2,302 posts
  • Joined 26-January 13
  • LocationBay Area + Taipei
Search his YouTube channel for racing videos.
Carmiwrx
Carmiwrx
  • 616 posts
  • Joined 15-March 13
  • LocationClarkesville, GA
Also, disconnect EVERY electronic connection, do the hokie pokie, and then check continuity
If the car owner has a hot lady, don't buy, they couldn't keep their paws off each other, you know there's gonna be sex mud, and not the good kind.
Ask the tuner of the car to tell you about how he tuned the car, then tell him he needs to explain in higher resolution, or you're looking elsewhere.
Edited by Carmiwrx, 18 September 2015 - 05:16 AM.
RIP: C. O, E. H., C.S-K.
I popped my motor after 4yrs and 8k miles which all of them were hard miles like a dude fucking his first piece of pussy after doing 5yrs in the joint. -Tim S.
GTR heritage - come get some!
  • 1,938 posts
What if the owner IS a hot lady?!
  • Tim and droptopp like this
Carmiwrx
Carmiwrx
  • 616 posts
GTR272
GTR272
  • 47 posts
  • Joined 13-August 15
IAN
I feel you are directing your post to me :wavecry:
Glad nightmare is over. Do you think driving on a 93oct map with 91 oct but driving like grandma 500 miles would hurt it?
this was something I've been thinking about posting for a while, sorry not directed at you specifically, but I did decide to make it after I read your thread.
I honestly can't tell you if what you did was an issue or not. if you had datalogs we would know for sure. I know I wouldn't have done that myself, but that is just my opinion, not based on anything. data rules all.
GTR272
GTR272
  • 47 posts
I did data log some on way home.
Also I was on M&H's on all 4 wheels and it rained 3/4 way home.
  • 9,227 posts
You drove on M&H's in the rain..brave man
  • Buschur Racing likes this
GTR272
GTR272
  • 47 posts
Wasn't planned but scary to say the least..
GTR272
GTR272
  • 47 posts
I can tell you those tires didn't like that trip.. inside corners were shaved off by time I got home
  • 9,227 posts
Yeah they have a specific purpose..I had a pair start chunking on me at 170
