Do I have to completely bleed the brakes for rotor swap?
- - - - - brake rotor bleed fluid
2 replies to this topic
awdtt
awdtt
  • 1,102 posts
  • Joined 14-August 14
I have to send in my ST rotors for reconditioning and am gonna swap back to OEMs for about a month or so.  I have the 2015 Service Manual, but it doesn't have a procedure for removing the rotor -- only the caliper.  (I'm guessing that I don't have to fully remove the caliper to get the rotor off).
But the Service Manual talks about bleeding the brakes.  Can I assume that they are talking about removing any air and topping off the master cylinder?  Do I need to go to all 4 wheels?
Also, I looked for a DIY on here for rotor removal, but didn't find one.  If there is one, does anyone know where it is?  If there isn't one, I'll try to make one, although it might be the blind leading the blind.
Edited by awdtt, 03 September 2015 - 08:06 AM.
2015 BE Frankenmotor
Once you remove the calipers the rotors just pull right off.  There is nothing holding them to the hub.
No need to bleed the brakes, because you won't need to loosen or remove the lines at all.
  • Tim, HiBoost, thehelix112 and 1 other like this
awdtt
awdtt
  • 1,102 posts
That's what I was hoping. Thanks!
Also tagged with one or more of these keywords: brake, rotor, bleed, fluid
