Forged Performance Steering Column Reinforcement Plates - In Stock & Ready To Ship!
forged performance steering column braces gtr r35 interior billet cnc fix
41 replies to this topic
Bobby@Forged
Bobby@Forged
  • 277 posts
  • Joined 08-December 14
Given that we track test GT-Rs almost on a weekly basis, we tend to uncover weaknesses that may not be known to everyone. When we first started noticing steering column mounting issues, we thought it was just a fluke of some sort and went about our business. But over the course of months, we've seen nearly a dozen GT-Rs succumb to the steering column mounting failure. Obviously, this is a very dangerous and unsettling situation, primarily occurring on cars that are tracked regularly due to the sawing, pushing and pulling forces that most drivers will place on the wheel.
When Sharif, the GM of Forged Performance, experienced this on his 2013 GT-R with only 5000 miles on the odometer, we knew that something had to be done.The OEM steering column and tilting assembly is mounted using some very weak pressed metal body clips. Even when they are very tight, they have a tendency to work their way off the mount, causing the steering wheel and cluster to fall about 3 inches downward into the drivers lap and about 1 inch laterally. Those of you that have experienced this know exactly what we are talking about. So we set out to design a unique mounting reinforcement block that solves this issue once and for all.
These Reinforcement Plates are CNC machined from billet aluminum and include locking nuts and washers for a lifetime fit. They are notched for unparalleled safety and security making it impossible for the column to walk off the mount. Maintaining full tilt and telescoping operation, we designed these pieces so they require absolutely no cutting or modification whatsoever with installation taking approximately one hour. These have been track tested and proven. Any GT-R that plans to see track time should consider this a mandatory safety upgrade.
(Because these pieces are located under the steering column, it isn't possible to photograph the right side bracket but these photos should give you an idea of where they are mounted.)
And some detailed product photos. These will also include installation instructions to aid you in this process.
If you have any questions, don't hesitate to ask. We have plenty in stock and ready to go!
PRICE: $99 Shipped
AVAILABILITY: In Stock
Order Here: http://www.forgedper...cat=2462&page=1
Or give us a call at 770-792-0202 with any questions or to order over the phone!
And what would this thread be without a helpful, how-to installation guide?
Photos to help with the Forged Performance steering brace Installation.
*****PLEASE INSTALL ONE BRACE AT A TIME IN ORDER TO KEEP COLUMN SUPPORTED *****
Remove access panel on the left side of the dash. There are four tabs which hold it on.
Remove the (2) 10mm bolts which holds hood latch on to trim panel.
Grab the trim piece on each corner indicated by the arrows. Firmly pull towards the driver's seat to loosen panel.
Make sure to unplug all connectors on panel. There are connectors on both sides of the panel.
Remove the (4) 10mm bolts, and remove metal bracket.
REMINDER, INSTALL ONE BRACE AT A TIME IN ORDER TO KEEP STEERING COLUMN SUPPORTED
  • Start with driver side, remove the 12mm nut and washer.
  • Install Forged Performance steering brace and tighten with supplied bolt and washer.
  • After completing drivers side, only then move to passenger side.
****KEEP ONE SIDE ATTACHED AT ALL TIMES!****
  • bpauto and sam2avila like this
Bobby Sanders | Sales Support
Bobby@ForgedPerformance.com
498 Cobb Parkway South, Marietta GA 30060
Forged Performance will meet or beat any competitors pricing!
facebook_32.png wordpress_32.png youtube_32.png vimeo_32.png flickr_32.pngtwitter_32.png
Nice!
  • 5,103 posts
Have this.
Very strongly encourage all track goers to get this.  There has FINALLY been a recall in Japan about this, but several steering columns have fallen into more than one laps while on track.
  • destroid likes this
  • 756 posts
Finally saw the steering wheel drop on a CBA - occurred to a local owner while in T2 @ COTA. He nursed it back around and into the pits w/o further issue.
  • 7racer, shawnhayes and choerizo like this
  • 2,026 posts
Have this too. Thumbs up!
Bobby@Forged
Bobby@Forged
  • 277 posts
Have a great weekend GTRHeritage crew!
Bobby@Forged
Bobby@Forged
  • 277 posts
Get ready for the weekend everyone! Give us a call, email, or web-store order for any GTR needs!
Bobby@Forged
Bobby@Forged
  • 277 posts
Hope everyone is off to a great week! Give us a call or email for any GTR needs! 770-792-0202 or bobby@forgedperformance.com
destroid
destroid
  • 75 posts
  • Joined 31-January 13
  • Location"Live Free Or Die"
Installed these today - well made and one less thing to worry about on track.
FYI the Forged plates and hardware only weigh 203g. Since you dont reuse the 23g worth of factory nuts the net weight is 180g - much lighter than the steering assembly in your lap!
  • ian.r, 7racer and Bobby@Forged like this
2013 GT-R Pearl White Black Edition
  • 7,777 posts
welcome to the forum destroid!
I have one installed on mine too, don't want the column failing while at the track!!!
  • shawnhayes and Bobby@Forged like this
destroid
destroid
  • 75 posts
Update with the weight:
  • Bobby@Forged likes this
Bobby@Forged
Bobby@Forged
  • 277 posts
Yeah, the added grams are worth not having the steering wheel and column fall in your lap, that's definitely a lot heaver!  :lol:
Bobby@Forged
Bobby@Forged
  • 277 posts
Hope everyone is off to a great week! Hit us up for any and all GTR needs!!
Bobby@Forged
Bobby@Forged
  • 277 posts
Gear up for the weekend! Give us a call or email for any of your ride's needs! 770-792-0202 / bobby@forgedperformance.com
Bobby@Forged
Bobby@Forged
  • 277 posts
Hump day! Give me a call or email with any questions or for any GTR needs! 770-792-0202
Bobby@Forged
Bobby@Forged
  • 277 posts
Hump day bump! Call, pm, or email for any GTR needs! 770-792-0202 or bobby@forgedperformance.com
Bobby@Forged
Bobby@Forged
  • 277 posts
Get a jump on the weekend's activities with some new orders! http://www.forgedper.../store/home.php
Bobby@Forged
Bobby@Forged
  • 277 posts
Happy Friday everyone!! Hit up the old webstore, give us a call, or shoot over some emails/pm's with questions! Get all those new parts you need this weekend!
http://www.forgedper...ance.com/store// 770-792-0202 / bobby@forgedperformance.com
Bobby@Forged
Bobby@Forged
  • 277 posts
Have plenty of sets in stock and ready to ship!
sam2avila
sam2avila
  • 115 posts
  • Joined 08-March 15
Looks like a good product for track junkies. I ordered a set via an international cargo forwarder at NV. Can't wait to get it :)
Also tagged with one or more of these keywords: forged performance, steering, column, braces, gtr, r35, interior, billet, cnc, fix
