Dave's slow, stealthy, Black Edition, HPDE-oriented build
712 replies to this topic
  • 4,425 posts
Hehe, if I had an ecutek and could do the cool abs/vdc system flush command in the ecu maybe I wouldn't be as worried about the air.
Shawn, yeah I hear ya. It's just kinda an expensive mod right now. And might complicate warranty issues on the transmission no? Nissan could just claim it was installed incorrectly.
Also, I got an oil change at the 1000mi, and got a sample. Blackstone is where people send for analysis right? I'm not sure what to look for, just looking to establish a baseline on the engine.
Oh and here is the start of the parts pile.
  • 5,135 posts
I had no idea it wasn't common practice to empty a brake system. How can it be bad when literally every car has to be filled with brake fluid on the assembly line. They don't install the calipers full of fluid or the lines or the ABS controller, etc so at some point the system is full of air and then it's full of fluid. I don't see a brake system being different than any other hydraulic system, there's no harm in flushing it dry so long as you get all the air out upon refilling the system.
But on the assembly line;, just as in regular life, the recommended process upon reassembly starts with a "bench bleed" - pre filling the critical parts with fluid because some parts are put together in a way that you can't get all the air out in the car.
If there's no difficulty getting all the air out - no problem, but multiple systems I have had in my career didn't fill properly when filled totally from dry while in the car.
ABS systems are notoriously bad for that characteristic.
  • 5,135 posts
To this point, most analyses have gone to blackstone. NickTo sent a couple to "oil analyzers" way back in 2009 (better analysis, but much more expensive)
Very little has been set in stone, but the cheapest oil anybody uses is Mobil 1, which is pretty damn good, you just have to keep it cool.
OEM tranny fluid holds up well to repeated 265F per my Blackstone analyses.  But the seals might be a weaker point.  Shawn, was it a seal that gave out on you?  The seals might degrade over time with repeated heat cycles over 250F, not sure, my HKS cooler typically keeps the tranny temps under 250F.   So....  on the tranny cooler I guess I recommend putting the HKS on if you are often going above 250F.
OEM Mobil 1 holds up well even when running the car into limp mode (279F ?) repeatedly, per my Blackstone analyses.
  • 5,135 posts
The code was consistent with either a seal or a sensor, but because the transmission was replaced, no one could know for sure.
Even though the oil might hold its lubricity up to 279, you don't want it to get that hot, because a 40 weight oil won't hold its film strength for superb bearing protection at very hot temps, because it gets too thin.  If you upgrade the weight to a higher weight, that helps, but the proper answer is upgraded oil cooling.
  • sam2avila likes this
  • 4,425 posts
Great info guys. Thanks! I wonder if they upgraded the seals on the later cars of if they're still an issue?
I guess I'll see how I go out there and make a judgement call on the day. The '14s are having transmission issues anyway I guess, at least my local dealer is aware of it, so if it needs to be replaced, so be it.
As an aside, is it just the speed of the gears squishing the oil that puts heat into the transmission? Or is it slip in the LSD more so?
  • 5,135 posts
We think the seals are a little better material than they were in 2009.  But, the sensors in the 2012's and up definately seem hardier.
The heat in the tranny is multiple...
1. Clutch - wet clutch slips and puts a lot of heat in
2. High horsepower - put high horsepower through a synchronized transmssion and they get hot.  Cannot be helped.  It's the power plus the spin plus the torque plus the shifting.
3. It's right next to the exhaust
4. The differential gets HOT, and it's connected to the tranny - so it heats it up.
5. AWD system - putting torque BACK, and then running it FORWARD AGAIN is a fairly inefficient design, and adds heat due to the mechanical components.
  • 4,425 posts
Gotcha. Thanks!
I might follow the gauge then, and just slow down if it gets near the yellow.
  • 5,135 posts
Gotcha. Thanks!
Make sure you're staying below 250 most of the time.  It's bad to keep expensive electronic sensors and seals anywhere above that.
  • 4,425 posts
Haha ok fine! :)
  • 4,425 posts
Back to the front tyres, I popped my hand under the front fender, and that liner's attachment is super freaking annoying. Lots of clearance wasted there. Will need to have a look under it properly and figure out something else.
Top outer part of fender liner, check there during your track days, if it's going to rub, I think it will be there first.
I'm guessing you are going to be OK though.  I got this rub with a 18x10.5 ET15 setup, so you have 10mm more clearance.
  • 1,756 posts
I ended up installing speed bleeders. Simple one person job now.
  • thehelix112 and NSMO like this
  • 4,425 posts
Icarus,
Interesting that you don't appear to have hit those enormous blocks on the fender liner.
I think the safest thing to do would be to pull the upright out, remove the spring, reinstall and check the full range of motion.
I'm used to working on Datsuns, that's about a 25 minute job. I imagine it'll take somewhat longer on this car.
  • 4,425 posts
I swapped the wheels front to back this morning to get an idea of how far it sticks out.
Quite a bit is the answer. Definitely going to need arms and/or bushes if this is going to work. Worth a shot I guess...
  • 2,052 posts
Yeah, I thought that might be the case. Those of us getting away with wider front wheels are running 18's and 19's with a much shorter tire than stock...
Dave, I still think there is a good chance of no rub. You won't know until the front suspension is under full compression. The wheel tucks in at an angle.
  • 4,425 posts
True. If I can find my spring compressors, and I wake up early, I'll pull one of the front shocks out and remove the spring so I can check the full range of motion.
Luv2XcelR8
Luv2XcelR8
  • 28 posts
  • Joined 24-February 13
I am really enjoying this thread..
Very good info, keep adding!!
-T
0486fe2b-7f6a-45aa-a194-ae34925fd7ba_zps
  • 4,425 posts
Thanks man.  Will do!  Just washed the car to get ready for it to have a rest at the in-laws, and for me to have a rest from worrying about it being parked out the front of my house.
I'll get a bunch more pics in a couple of weeks.
