AP Racing radi-cal street/track brake kit
18 replies to this topic
15170868455_cc365b1858_b__34988.14109551
http://www.apracing....p8521z1000.aspx
New
Factory
Radi-CAL™
Big Brake
Kit with
Ø410mm
x 36mm
thick
discs.
Kit uses
new
forged
World
Radi-CAL™
6 Piston
caliper, which offer a significant weight reduction
in mass compared to conventional designs
through applying AP Racing's patented Radi-CAL™
design concept.
Kit Part Numbers :
- Black Caliper Kit Number -
CP8521Z1000BG.CG12
- Red Caliper Kit Number -
CP8521Z1000R2.CG12
- Kits are available with GA 'J' Hook disc face
types. Please contact AP Racing or one of its
Distributor/ Authorised Dealers for information.
IMPORTANT NOTE:
Before purchasing or installing a factory Radi-
CAL™ big brake kit, make sure that the brake
upgrade is suitable for the make and model of
the vehicle, and that the wheel has been checked
for clearance
Icarus posted this in his thread, but thought it a good idea to make its own.
its a massive kit, not quite a race caliper, wonder how it compares to the stock, or its used just because it can accommodate the larger rotor?
here is what a real race radi-cal caliper looks like
http://www.gtrherita...ge-2#entry53898
  • 4,963 posts
Nonstandard pad. This kit will live in the Alcon stratosphere. Good kit I'm sure, but too expensive.
I'll put my Racing Brake ones against them anyday.
  • Warren-RB and mikelmarion like this
jdmrb1
jdmrb1
  • 340 posts
  • Joined 22-February 15
  • LocationYokohama Japan
It's only 6K for a Front and Rear Kit complete 410/400 rotors !!
Warren-RB
Warren-RB
  • 503 posts
  • Joined 20-January 14
Can you please post the link so other members can see the offer details.
www.RacingBrake.com
jdmrb1
jdmrb1
  • 340 posts
For sale on JDL the AP part # is CP8521Z1000BG.CG12
Edited by jdmrb1, 17 May 2017 - 03:55 PM.
  • 4,963 posts
Front kit is $2879 from JDL before shipping from the UK.
  • 7,409 posts
so what brake pads are usable in this kit?
jdmrb1
jdmrb1
  • 340 posts
AP UK uses Ferodo a lot, always can use the supplied pads for street and order special made from endless in your compound of choice.
drk
drk
  • 115 posts
  • Joined 06-January 14
just finished 2 days at INDIE. Ran 8x20 min and 3x15 mint sessions. Only two cars had faster times, and open wheel racegroup car was 2-3 seconds faster and a modified ACR with full slicks only running 2 hot laps per session for  TT was a few 10ths faster and he was overheating. No fade no problems. Was 2 seconds faster than my previous best but likely due in part to the new DSC controller and tractive RTx suspension which I will review on the DSC thread. Bob at BSE Performance inspected the brake and said you would be hard pressed to even say the brake or pads had even been used.
  • changster, 7racer, thehelix112 and 5 others like this
  • 1,525 posts
What's JDL?
drk
drk
  • 115 posts
By the way temps ran into the low 90's over the weekend. Also I was able to brake later into the high speed corners. Prior to the AP bakes I had oem calipers and PFC 08 pads which are phenomenal pads,ungodly expensive but I'd wager better than the ones you are currently running by a long shot. I went through several of the pads and they, without exception wore completely flat. My guess is the AP pads will be just as good and less expensive.
  • 4,963 posts
What's JDL?
http://www.jdl-brake...0x36-6-pot.html
UK Brake company.
jdmrb1
jdmrb1
  • 340 posts
Talking with a few UK drivers. Good reviews so far.
jdmrb1
jdmrb1
  • 340 posts
What pads are you running with the AP kit. ?
Tay
Tay
  • 38 posts
  • Joined 17-March 13
Just to be clear, there are two different AP Racing kits. One is more street oriented:
Front
https://www.apracing...p8521z1000.aspx
Rear
https://www.apracing...p8540z1000.aspx
And the other on is a race/track kit by Essex Parts which I believe drk is running. This kit also uses more traditional/common pads:
Front
https://www.essexpar...668390mm-r35gtr
I believe they are also working on a rear kit.
https://www.facebook...155250659658608
Warren-RB
Warren-RB
  • 503 posts
$5500 is very comparable to a full RB CCB brake kit.
Some advantage of CCB kit over conventional iron kit:
  • Bullet proof performance and lasting durability proven by track only in a Mustang GT350R (w/sintered pads), and Porsche 991 Turbo and Cup car for professional racing.
  • Brake disc is a same as ZR1/Z28 front easy to source (online or GM dealers) at low cost (swap the disc and re-use RB hats).
  • Brake pad is a standard FMSI configuration (Swap with OE GTR pad D1382 or upsize to ZR1 pad D1395) for multiple choice of compounds and suppliers at low cost.
  • Even calipers are swap-able between RB's and GTR, RB calipers are made from forged aluminum alloy and is a direct mount to OE upright w/o needing any spacer.
You have full control after you purchase RB CCB kit for future maintenance and replacement w/o having to contact us but of course we are available if you ever need it. If you think hard on the 100% interchangeability of RB CCM to OE iron, you know you will have a complete "back up" set of components with you in case something happened it's always can be under your own management w/o panic - A distinct feature only available from RacingBrake no one else can.
Should you still consider and settle with these conventional iron kits and worry about the wear and tear or fading etc. while CCM brakes has been made so affordable and reliable these days.
Edited by Warren-RB, 22 September 2017 - 11:15 AM.
www.RacingBrake.com
gogospeed
gogospeed
  • 2 posts
  • Joined 23-September 17
just wondering will this kit (the 410 one) fit an 2008 model?
jdmrb1
jdmrb1
  • 340 posts
Yes it will.
gogospeed
gogospeed
  • 2 posts
hey mike :) , thanks
  • jdmrb1 likes this
