JCR Carbon Fiber intake manifold
- - - - - jcr carbon fiber cf intake manifold
95 replies to this topic
#81
Hi all,
We are excited to release the first official pictures of the production spec JCR Carbon Fibre Inlet Manifold.1fa904b9344d76242f82ac5f59b20f2a.jpg
The JCR Carbon Fibre Inlet Manifold features full one piece Carbon Fibre construction utilising the latest CAD & CFD technology, fully replacing the upper and lower section of the stock VR38 Inlet Manifold.788b9e50ffbc7d2686b262ce95bfefaf.jpg
The JCR Carbon Fibre Inlet Manifold not only achieves great gains in horsepower and torque, reductions in spool time and lowered boost threshold and an overall improvement in efficiency, but is also a beautiful looking piece of engineering which brings new life to any R35 GTR engine bay.7618ca930c4628b62289bbec5e65ca4b.jpge1d7052d3ed0c7fc6e7cab5f1ce86925.jpg
We are now in the final stages of testing with the official release set for March 2015.4256c4635011d7c3597ce366fa8700dd.jpg
To registed interest and secure one of the first build slots for the JCR Carbon Fibre Inlet Manifold please contact SALES@JCR-GTR.Com and if you have any questions at all please feel free to ask.
Regards
Jonny
damn that is tight!!! function and beauty
  • Evolunchbox and JCR_GTR like this
#82
  • 7,630 posts
All one piece, just simply the mould lines from production, the Inlet Manifold is 100% one piece construction with only the balance pipe and Billet Aluminium Base plate bonded in post cure. This guarantees structural integrity and keeps the weight down to a minimum while maintaining huge strength.
We're very excited to share the testing results come release :)
Jonny
damn!  NICE JOB Jonny!!!!
  • JCR_GTR likes this
#83
VR38DETT
VR38DETT
  • 54 posts
  • Joined 17-March 13
We have moved the throttle body in the same plane, outwards by a small, yet significant amount. The idea was to allow customers to retain the use of their stock / aftermarket upper pipes, there was no real advantage moving the throttles any further so its a win win.
We will also have the JCR Carbon Fibre BOV Pipes available soon.. With and without BOV flange.
Hope that helps :)
Regards
Jonny
It does help, thanks. Pics look great! I'll be sending you an email tomorrow. Sign me up!
#84
JCR_GTR
JCR_GTR
  • 108 posts
  • Joined 12-December 14
  • LocationUK
Thanks again, and look forward to your email.
Jonny
#85
CasualObserver
CasualObserver
  • 611 posts
  • Joined 11-August 14
Looks like a damn nice piece! Those long runners looks like they will give a nice boost on the low to mid range.
#86
  • 7,630 posts
can someone explain some basics to me about runner length etc and where it helps/hurts?
#87
div
div
  • 155 posts
Think about drinking water through a straw or through a garden hose, both equal length. Same 'low' volume of water would flow faster through the straw due to small cross-section (response) but same 'high' volume of water would flow easier in the hose (power). So to optimize both response and power, you would optimize runner's diameter and length (along with intercooler piping and volume and plenum volume etc), with probably some bias against either response or power. Therefore, in some naturally aspirated engines, you'd see dual runners: lower diameter for lower engine speeds and larger diameter for higher engine speeds and, naturally, higher power. The ecu would control a valve that switches between either runner.
#88
  • 3,909 posts
  • LocationOmaha
In addition to what div said, there is also the concept of wave tuning.  Just like different length tubes in a musical instrument produce different frequency tones, if you can match up the target rpm to the corresponding length/area of runner you can benefit from a type of supercharging effect.  However, it is debatable (IMO) how effective this actually is when dealing with vehicles that are already boosted.  If you wish to spend your day running scenarios you can find lots of calculators like this:
http://www.velocity-...calculator3.htm
#89
JCR_GTR
JCR_GTR
  • 108 posts
  • LocationUK
The runners actually appear a lot longer, and smaller than they are, due to a couple of reasons:
The wall thickness of this piece is 4-5 times less than the stock cast aluminium inlet manifold, and up to 6-8 times less than some of the aftermarket manifolds. This is due to the limitations you face when casting aluminium, you need a good space in the mould for the material to flow during the casting process, with Carbon Fibre, this is a non issue.
Also, the fact that we have swept our runners and the lower portion is open showing individual runners rather than the usual one piece design found in the cast lowers does give the impression of more length.
Pressure differential is taken care of in the plenum, and the velocity is determined largely in the runners, the correct taper and internal shape is critical, that is the main reason we went to a full one piece design which has allowed us to make the transition from the head port shape to the round of the bell mouth over a much longer length. Without giving too much away, we are more than happy with where we have arrived at with the design of our Manifold :)
As for the looks.. 'Form follows function'
Thanks again for the comments
Jonny
  • Tim, 7racer and bpauto like this
#90
changster
changster
  • 2,302 posts
  • Joined 26-January 13
  • LocationBay Area + Taipei
Pricing?
#91
cjb08
cjb08
  • 206 posts
  • Joined 12-April 14
Also interested in price.
#92
JCR_GTR
JCR_GTR
  • 108 posts
  • LocationUK
Pricing?
Hi Guys,
The speculative pricing at this time is £4500 ($6785) plus shipping. We will have this nailed down very shortly, but I'm pretty confident we should meet that price point.
Hope that helps
Regards
Jonny
  • Tim, Ancalagon, 7racer and 2 others like this
#93
what about 2nd fuel rail version? Im sure there will be a few looking for that one.
#94
JCR_GTR
JCR_GTR
  • 108 posts
  • LocationUK
That is on the way, the parts are still currently in development but far less of a technical challenge to create. We expect to launch the 3rd rail 12 injector option shortly after the general release of our regular 6 injector manifold :)
Jonny
  • Tim and ian.r like this
#95
VR38DETT
VR38DETT
  • 54 posts
Jonny
Can the standard manifold be upgraded to the 3rd rail?
#96
JCR_GTR
JCR_GTR
  • 108 posts
  • LocationUK
It certainly can be, but the Manifold would have to come back to us for the upgrade. The turn around time would be around 3-5 days.
Jonny
Also tagged with one or more of these keywords: jcr, carbon fiber, cf, intake manifold
