The biggest lesson for me was learning what those voltage charts all over the internet meant.
http://gtrtech.blogs...ry-in-gt-r.html
DIY Guides Related to my GT-R Projects --> http://gtrtech.blogspot.com
I did not find it necessary to remove the white plug, that is designed so the panel can slide in and out using the head's channel as a guide. Those little doodads have been used for years so that a panel can be removed, but only in one direction. It can be slid into place, and then secured only using one fastener. That is not how it is used in this application, but it does make that panel fiddly to remove.
Nice work on the DIY's. You are much appreciated.
DIY link added to the DIY links.
Edited by shawnhayes, 16 February 2014 - 12:16 PM.
like the DIYA also!
I really liked my titan/lithiumpro battery setup but the battery had issues with the recharging from the factory alternator. Almost everyone with this battery has had them fail. From what it sounds like it would have been best to use the lithium pro in car, then disconnect and put on a trickle charger made for lithium batteries.
I was watching Motorweek on PBS and they had a battery expert from a battery manufacturer on, and he said it is actually the heat that shortens the life of a battery and when cold/winter weather comes is when you realize it and have to replace the battery. I can't remember witch episode it was.
http://video.pbs.org...-week/episodes/
http://www.youtube.com/watch?v=KjHFTHXZ7OEhttps://twitter.com/KIRIN_CARIBOON
Both are responsible. Extreme cold increases the internal load, which increase sulfation rate, a known killer of batteries. Bet on 5-7 years at best. Any more than that is gravy and you are in "the bonus round". But, always recycle and nothing is lost. The lead needs to go back to the car battery makers, so we can keep it out of the resource stream.
Does anyone have any opinions on AGM batteries?
http://www.summitrac...5100r/overview/
Its time for a battery in my car.
2011 Nissan GTR Gun Metallic
Switzer P800
Switzer Premium 90MM Stainless Steel Exhaust
Switzer Engine Cooling Package
Cobb AccessPort
H&R Springs
Custom Pine Tree Air Freshener from AutoZone
ADV 10 Deep Concave Wheels with Pirelli P Zero Nero Tires 355/25-21 / 285/30-21 Titek Lugnuts
not sure...they "look" like repackaged batteries...
I see the D680 is the same size and ?same specs as the Lithiumpro L680
http://lithiumpros.c...rpack-with-bms/
http://4xspower.com/.../d-series/d680/
it might have the same problem with taking a charge from the alternator and charging from dead. They seem pretty inexpensive. I might give the D680 a go.
sorry...so these are AGM? (just googled it)....would these be more durable than the liPO4?
Edited by 7racer, 16 February 2014 - 04:38 PM.
Weather got nice and I wanted to drive my car. Went to the dealer and bought an OEM replacement for $100. Installation was easy pretty easy. You have to remove the molding around the bottom of the windshield so my advise would be to be careful when you swinging tools close to the edge of the glass.
Switzer P800
Cobb AccessPort
H&R Springs
Been working with enshiu on my car for the past 2 days. This guy is a mad scientist. He knows his stuff about GT-Rs. We spent the past few days changing brakes, rotors and upgrading my gotboost full intercooler piping. Enshiu will post pics of my car later.
