Revisiting the E900... 900+whp possible? Cobb Flex-Fuel?
- - - - - switzer switzer performance e900 p800 e1k goliath cobb accessport e85 ethanol
Neil Switzer
Neil Switzer
  • 375 posts
  • Joined 20-December 12
I didn't think it would be, but Tym proved me wrong. Here's a dyno sheet of where we're at so far with the latest E900 GTR build. It may as well be the E1K since it's making an easy 1000HP - but that's not what's most impressive. It's the 100 more ft-lbs of torque this thing has at 2500rpm than a stock 2014:
Add about 2.5-3% for STD correction factor numbers.
We still have some fine tuning left but so far this thing is blowing me away. The second you tip into the throttle it's making boost. Tym's been working on evolving our turbo hardware whenever possible, these latest snails can really move some air while still staying efficient at higher rpm. With such a broad torque curve, this might just be the most fun-to-drive street build we've done yet, and I wouldn't even hesitate to take it down to Mid-Ohio to burn up a set of tires, either!
Last but not least... the Cobb Flex-Fuel is coming together nicely on this beast. thumb.gif
  • Tim, ian.r, TheHitman™ and 4 others like this
"All around nice guy"
  • 3,998 posts
Neil,
Cool.  What fuel is that on?  Flex-fuel mentioned.. implication being E85?
Edited by thehelix112, 04 February 2014 - 06:41 PM.
cjmatt
cjmatt
  • 453 posts
  • Joined 29-January 14
  • LocationDetroit
What's done to the engine and trans to hold this much?
Ricky Ricer
Ricky Ricer
  • 184 posts
  • Joined 08-March 13
  • LocationLakewood, CO
Can't wait to see this beast in person! Nice work Neil.
-Rick
gtr34
gtr34
  • 201 posts
  • Joined 23-March 13
  • LocationPa
In for the specs too......?
Neil Switzer
Neil Switzer
  • 375 posts
Neil,
This is being tuned on pump gas and E85, the graph above was on E85.
The engine is our standard stage 1 build:
***Switzer Stage 1 VR38DETT Engine Build***
- Switzer Spec Mahle Pistons, Pins, and Rings
- Switzer Spec Carillo Connecting Rods
- Switzer Spec Camshafts
- Switzer Blueprinted Engine and Oil Pump
- Switzer Spec Nissan Engine Components
- Engine Teardown, Cleaning, and Reassembly Labor
- Switzer Engine Oil and Filter Change
- Switzer Professional Engine Break-in Procedures
This transmission was done by another transmission provider that we don't typically use. First gear, mainshaft, clutches and baskets are recommended.
Thanks Ricky, wish I could take all the credit for it but that goes to the guys behind the scenes for making a great product.
GtRcHaRgEr
GtRcHaRgEr
  • 247 posts
  • Joined 11-January 13
What were the pump gas dyno numbers? By the way nice power curve and displaying it in SAE.
09 Black on Black Premium....... AMS 4.4 Stroked ALPHA 12 Powered TSM Tuned!
Neil Switzer
Neil Switzer
  • 375 posts
Hasn't been dyno'd on 91 or 93 yet, but I'll post those when we do the full release on the build. We custom built these turbos and it paid off, they spool harder and breath better up-top than the cut-down GT30's stuffed in a stock manifold that seems to be all the rage these days. Unfortunately those like to run out of steam at 6500rpm.
TheHitman™
TheHitman™
  • 561 posts
  • Joined 26-December 12
  • LocationMexico
But hey I like my cut down GT30's :(
This is still a sick build.
Violent Blue 2012 GT-R Black Edition
sick indeed! way to go switzer innovating your lineup even more.
GtRcHaRgEr
GtRcHaRgEr
  • 247 posts
So how many revisions has the E900 gone through?
Neil Switzer
Neil Switzer
  • 375 posts
This is the first one, and quite honestly we might be calling this the new E1K, it's making a legitimate 1000HP at the crank.
Also tagged with one or more of these keywords: switzer, switzer performance, e900, p800, e1k, goliath, cobb, accessport, e85, ethanol
