DIY: How to Change Spark Plugs
33 replies to this topic
  • 5,202 posts
It's always safer to go with a torque rating (don't know what's the number for our car), especially if you're reinstalling one. By the way, the 1/4-turn spec is for conical seats and reinstalled crush washer plugs. With new crush washer plugs (like the OEMs), it's usually 3/4. But it's impossible to measure that with the little space available, so invest in a torque wrench and do the job right ;). Having said that, never seen a spark plug so freaking long; that's crazy. Probably a turbo thing, since this is my first such car.
Nah, just a very deep head.  Plug thread length can be relative to "cool" or "hot" plugs, but that one is so long because the head top to combustion chamber distance is so great.  You can see on the threads that only the outer 1/3 of the plug is in the combustion chamber.
Rick5150
Rick5150
  • 4 posts
  • Joined 30-March 17
It's always safer to go with a torque rating (don't know what's the number for our car), especially if you're reinstalling one. By the way, the 1/4-turn spec is for conical seats and reinstalled crush washer plugs. With new crush washer plugs (like the OEMs), it's usually 3/4. But it's impossible to measure that with the little space available, so invest in a torque wrench and do the job right ;). Having said that, never seen a spark plug so freaking long; that's crazy. Probably a turbo thing, since this is my first such car. great write up
Great write up on the plug change!
FYI for the next guy spark plug torque for our cars is 20 nm or 177 in lbs or 14.75 ft lbs
  • Enshiu, 7racer and choerizo like this
  • 386 posts
https://www.ebay.com...YBaUmZq&vxp=mtr
I bought these. Cheaper than dealer price.
It is discounted at 89.99$
Edited by Enshiu, 21 February 2018 - 07:42 AM.
gtrguyinaz
gtrguyinaz
  • 121 posts
  • Joined 26-April 17
I can't believe it is this extensive to replace spark plugs.............
What happened to look down , pop the wire and unscrew the plug.......
  • 386 posts
You also need a 5mm Allen bit/T30 torx screwdriver for the plenum cover.
All v6 are like this now
Yes 60k mls / 100k km or 5 years.
NGK DILKAR8A8 - 93026
Shell
Center Electrode
Ground Electrode
Specifications
  • Torque Specs: Cast Iron: 10.8-18 lb. ft.    Aluminum: 10.8-14.5 lb. ft. / 14.65nm - 19.66nm
  • Brand: NGK
  • Heat Range: 8
  • Longevity: 80-100k / 5 Years
source: https://www.ngk.com/....aspx?zpid=9718
Dont overtorque your spark plugs as this may hit the pistons.
Edited by Enshiu, 23 February 2018 - 05:58 PM.
  • 386 posts
I did my spark plugs all on 16nm retorqued.
Edited by Enshiu, 06 September 2018 - 03:58 PM.
  • celsius and 7racer like this
celsius
celsius
  • 490 posts
  • Joined 31-December 12
Enshiu, have you noticed an improvement with the Okada Plasma coils?
1426 AWHP
8.75 @ 163MPH Tx2k19
190MPH Roll Race @ Tx2k19
  • 386 posts
I installed those 5 years ago......
A little bit noticable at the mid range rpm.
Edited by Enshiu, 21 September 2018 - 07:50 PM.
  • 535 posts
I can't ever remember any "V" engine being that easy. You must be reminiscing about the inline 4, FWD days.
  • 386 posts
He was thinking of the v6 in the 3000gt or 1MZ 3VZ engine those were a pita.
  • 5,202 posts
Definitely disagree...
My first car....
The motor:
See the spark plugs and wires?
Replacing those plugs, with the proper tools (had to have either a "spark plug wrench", or a ratchet with a flex extension on it), took about 15 minutes.
Replacing the distributor cap, AND rotor, AND wires added about 15 more TOTAL minutes to the job.
Plugs were about $1.35 each.  Cap was about $6.  Rotor was $3, wires were $10.  Well, it was 1985 too.
But other than there being 8 plugs, it took almost no time at all.
  • 5,202 posts
Oh, and just for fun, it required API SC rated oil.  And had a chart in the manual for which one was most appropriate for your temperature range.  And NOTHING in the manual went from 0 deg to 100 deg F, which was the temp range where I lived.  Winter we used 10W-30, summer 20W-40 if you could find it, or just straight 30 or 40 weight.  By 1985 we DID have 10W-40, which wasn't in the manual from 1967 and no one knew if we could use it year round (I still don't know amongst the crap SF spec oils we had at the time if they were even heat stable).
We've come so far.  If you could go back to 1967, buy a Fairlane, and put modern SN 0W-40 into the damn thing, it'd probably make 200,000 miles.  AND modern transmission fluid in that old C4, which would last nearly 90,000 miles on THEN available "Ford type F" transmission fluid (modern F-spec is wayy wayyy better) the cars mechanicals would probably last as long as modern cars.  Of course the dashboard, which was the crash zone for your face, and made out of solid metal wasn't very suitable then or now for crash standards.  But what we could do if we could go back.
  • 535 posts
My first car....
The motor:
I still can't remember. That was way before my time. Lol
  • 386 posts
If you use copper grease on the spark plug threads don't go over 12 ft lbs as it has grease on it
it will torque 10% more  than the wrench says due lubrication.
Edited by Enshiu, 21 September 2018 - 07:57 PM.
