Caliper differences on R35 GT-R's
23 replies to this topic
  • 5,189 posts
With other's help, we have discovered some important differences in GT-R calipers. Credit to Warren from Racing Brake and Evolution VI. Details to follow as I bring them here: Credit to sources where credit is due: EvoluitionVI here, and Warren from RacingBrake. Heavily plagiarized and shamelessly copied including source. Shawn
Edited by shawnhayes, 21 September 2013 - 07:48 AM.
  • 5,189 posts
Does anyone know there are three different FRONT calipers for GTR:
41001-JF20D (12/2008 - 12/2010)
41001-KB50A (12/2010 - 11/2011)
41001-KJ10A ( 11/2011 to present)
I believe most of you think only two calipers; One for 09-11 (380mm rotor), and one for 12+ (390mm rotor), and the difference is the height of caliper due to different rotor size all else (offset) is the same.
The other query I have is why the rotor thickness was changed from 34mm to a thinner one (32.6mm) in 2012 model - This never happens to any car make/model that I have known (newer model with thinner rotor).
I suspect the earlier (09-11) brake set up might have clearance issue (not enough clearance between rotor and caliper), so OE reduces the rotor thickness to alleviate this issue, but at the same time increase the rotor sizes to 390mm to make up the thermal capacity. However larger rotor also means more flex to both caliper & rotor - especially for tracking in high speed sharp turns, so I am not sure if this change could actually improve the interference issue they tried to correct unless the new calipers have wider clearance.
It seems to me that the interference between the rotor and calipers is contributing to the rotor premature failure (cracking) due to the excessive heat.
Anyone with insight to share your knowledge and experience will be helpful to the community.
Edited by Davin, 05 August 2013 - 05:38 PM.
From Warren of RacingBrake.
Edited by Davin for forbidden vendor activity
  • 5,189 posts
Credit to Evolution VI
I'm not sure I understand. The DBA caliper is only different to the CBA caliper in that the built in spacer is 5mm thicker.
With the DBA caliper, you'd need a 7.5mm spacer to fit to a 405mm rotor, and you'd need a 12.5mm spacer with the CBA caliper, but the pads would contact the rotor in the exact same spot.
Prototype of this concept is the Stillen CCM's, DBA's need 5mm spacer, CBA's need 10. Other one is AP's replacement rotor for DBA's - CBA cars can use it, and Stillen supplies a 5mm spacer.
Other than the extra 5mm on the mounting boss, the calipers are physically dimensionally the same.
No,they are def different.
Not sure how to describe it with my limited english knowledge,but i try my best.
If you measure the opening of the DBA caliper,its like 1cm more on the DBA cars compared to a CBA car.
I will upload a picture i just made....
Edited by EvolutionVI, 05 September 2013 - 06:02 AM.
  • 5,189 posts
Credit to Evolution VI Not the best pictures as i just snapped them,but clearly to see that there is a 1cm difference in the CBA/DBA calipers(due to the angle of the pictures it looks more like 5-6mm,but that doesnt matter....difference is there) Alex PS: To go from 380mm to 400mm it needs a 13mm spacer,to have enough clearance on the outer edges..... For 390mm to 396mm it needs a 5mm spacer,for 390mm to 400mm it needs a 6,5mm spacer Attached Thumbnails y5ysaqyg.jpgrytasume.jpg Edited by EvolutionVI, 05 September 2013 - 06:21 AM.
Edited by shawnhayes, 21 September 2013 - 07:31 AM.
  • 5,189 posts
Again credit to Evolution VI
shawnhayes, on 05 September 2013 - 07:29 AM, said:
Good work, man.
I just measured my Stillen spacer. Stillen had implied at some point that the CBA spacer was 10mm and the DBA spacer was 5mm. Having just measured it, it is indeed 13mm.
Our prior comparisons were from photos for the CBA and DBA calipers. We knew that the mounting bosses were different by 5mm. Had no idea they were longer.
Thanks for the excellent sharing.
Are the piston sizes the same or not?
Opening is 315mm CBA vs 323mm on the DBA,measured on the same spot of the calipers.
Pistonsizes are the same 26/30/32mm for both calipers.
The difference of the opening is the reason you will get problems installing the 400mm or bigger discs in the CBA but having no problem installing them in the DBA....maybe this clears up.
  • 5,189 posts
Credit to Warren from RacingBrake Another evidence to support my observation is the non-standard bolts used in 2012 GTR calipers: gebasezy.jpg As you can see the non-standard (modified) bolt has a shank diameter only 11mm which allows movement (slack) inside the caliper mounting holes (for offset adjustment), I was informed by some GTR owners/shops that factory instructions in installing the calipers is to press the brake pedal first before tightening the mounting bolts which is also something I have never heard of, because if all components are made correctly they should line up as they are intended w/o this type of correction at installation. This bolt variation has caught my attention to check further on other year's calipers. I saw a thread promoting ZR1 carbon rotors (36mm) with stock GTR calipers (37mm groove), unless the calipers groove is widen you can expect constant interference on tracks which is not a good idea to run. Edited by Davin, 05 August 2013 - 05:40 PM. Warren-RB
Edited by shawnhayes, 21 September 2013 - 07:46 AM.
anyone talk to Warren? im interested in hearing about his caliper development(s).
  • 5,189 posts
anyone talk toWarren? im interested in hearing about his caliper development(s).
Not yet. I'm thinking about calling him tomorrow. He should post here, without fear from being edited.
  • ian.r likes this
I remember his post about the development of the forged caliper ETA this summer.  Would love to give those a try!
sjj31
sjj31
  • 62 posts
  • Joined 15-September 13
Has anyone tried the 13 calipers on a 10? I have a buddy who upgraded to Alcon and thinking of buying his 13 calipers ... Any adjustment needed?
2010 Nissan Super Silver GTR – New Build April, 2014 @ 32,000 Miles (After 3 years of Bolt-On Fun!)
Engine:
Jack’s Transmissions Engine Refresh (Forged Manley Rods & Pistons,Gaskets, Bearings, Seals etc.) + Heat Shielded Engine Bay
Turbo’s:GTC Stock Frame Spec V Turbos,Ported Upper/Lower Manifold,GTC 60mm Inlets,AMS 4Bar MAP Sensor
Tune:EcuTek – Ben Linney SD Tuned 93 Octane using Gotboost SD Kit
Fuel/Injectors:Walbro 485 Pumps with AMS Hobbs Switch & Hardwired and Jack’s Seals,SIR 1150cc Injectors
Bolt-Ons:HKS Legamax Catback,HKS Non-Res Midpipe,GTC 90mm DP’s,Gotboost 3" Intakes w/Green Filters
Tranny:Built Stage 2+ - Billet Dodson Baskets A&B+PPG 1st Gear,Jack's 16 plate Clutch & Bell Housing Upgrade (drives like stock)
Cooling: ETS Intercooler/GotBoost IC Piping,SSP Tranny Cooler,Dodson Oil Thermo, AAM Oil Catch Can
Brakes: Alcon HD 396mm/JHook Rotors,Forged SS Lines,Hawk DTC 70/60 Pads,Upgraded OEM Painted Calipers (RB Stainless pistons/blue melt-proof seals/boots)
Fluids:Shell Rotella T 15w40 Engine (Jack's recommended), Castrol Diff, Jack’s Special Tranny Mix, Castrol SRF Brake
Wheels:Yokohama AVS F7 20x10+30,20x11+25,TSM Track Spacers (10/15mm),Toyo R888 285/35/20,315/30/20
Track:SFS Strut Bar,Eibach Sways,KW Sleeves,APR100-7718 Studs 12x1.5,Muteki Lugs,Sparco Harness Bar,Shroth 4PT,Difflow 5E Diffuser,Forged SW Lock
Look:DF CF Side Sills,Spats,ExShrouds,Rexpeed CF-M Splitter,OEM DRL's,SP LED Kit,GTMotoring Tow Hook
Extras:Hushmat Ultra (rear&trunk),Front Clear Bra,Full Tint,Clear JDM markers,Escort 9500ci Custom,VBOX
sjj31, it should work, but I am curious...I had a bitch of a time fitting the WGP CC ZR1 kit to my 09 calipers.  Wondering if the later models would fit better.  Also, if Warren fabbed up his forged ones to fit later models.
  • 5,189 posts
Based on the bigger caliper pocket, the fit may be better. Although, my CBA calipers had no trouble with the Stillen 400mm rotors.
  • Santorican likes this
Johnnypbmx
Johnnypbmx
  • 123 posts
  • Joined 25-February 14
I have the top secret bbk to go from my cba 380mm to 400mm. I have all the spacers but no bolts- do you know what size/ length bolts ill need to order front/rear? Thank you!
  • 5,189 posts
I'm trying to locate Sean Morris.  The rears will be the same that Stillen specced for the CBA for their CCM kit.  the front stock ones are long enough.  Other person to ask will be Warren at Racing Brake.  I think you need 10mm longer rear 10mm bolts.  The stocks will PROBABLY hold, but Stillen wanted longer ones.
Johnnypbmx
Johnnypbmx
  • 123 posts
Thank you! I did contact RB to find out what to order but they sent me a link for a full kit including spacers. I installed initially with stock bolts and seemed iffy- i may measure the entire hole then order 10mm less. Thought i could take the easy way out haha. Would you happen to know the stock bolt length and thread pattern? As always- much appreciated!
  • 4,584 posts
I've got the bolts Shawn sent me that I think are supposed to work with spacers? Shawn? I can measure em and get a photo tomorrow morning if it'll help. I'm a bum and they're not on the car yet. Close though!
  • 5,189 posts
Dave,
Those work with the RB Calipers.  The spacers for the rear brakes for the CCM's from Stillen/AP require longer bolts than the stockers - but not much.  Just a little.
I think the bolts you have are VERY close to the right length.  But I'm not 100% certain.  Do you know the diameter of the ZR-1 rotors?
Johnnypbmx
Johnnypbmx
  • 123 posts
Ive had good luck with this company for metric fasteners on price/quick shipping- just need to find out size/length- itd save me from pulling my current bolts out and trip to hardware store!
The allen heads are 12mm x 1.5- just need length
And not sure what the center bolt is for sizing.
https://www.belmetri...-heads-c-6_339/
Edited by Johnnypbmx, 25 March 2020 - 11:25 PM.
Front Caliper bolts:
Upper - M12 x 1.5 122mm long
Lower - M12 x 1.5 101mm long
Middle - M8 x ? 116mm long
Rear bolts are the same as the lower fronts. You can find all of them at mcmaster.com aside from the upper fronts. 122mm is longer than any normal supplier will make. :(
Johnnypbmx
Johnnypbmx
  • 123 posts
Thank you! This helps a lot! Ill pull the middle bolts soon and post thread pitch
Since I have a cba and going 380mm to 400mm i may be able to just buy dba brake bolts as they may be longer than 122mm? Then just use front bolts for the rear- from nissan the bolts are <$5 each.
Edited by Johnnypbmx, 29 March 2020 - 09:18 PM.
